I have 3 light/fan combos on the patio that look like the image. Each light/fan combo has a light and fan pull chain. They work exactly as you'd expect. All 3 light/fan combos power off a single light switch inside the house.
I want to make the lights dimmable. If I were to replace the on/off light switch inside the house with a dimmer switch I think that this would. However, I'm also assuming that if the lights were dimmed to half power on that dimmer that the equivalent would happen to the power going to the fans (all come off same switch).
Before I try this, what do I look forward to experiencing? Am I just going to see a slower fan when the lights are dimmed? (I can live with that because the fans have 3 speed settings and high is way too fast to ever be used.) Or are there other consequences? And finally, is there a different solution to achieving dimmable lights on a light/fan combo?
  • Can you post photos of the inside of the boxes involved please? May 20, 2021 at 11:40
  • @ThreePhaseEel - the light/fan combo box?
    – Guy
    May 20, 2021 at 17:55
  • Both the light/fan and switch boxes May 20, 2021 at 23:04
A "regular" dimmer, when used on a fan, will slow the fan to whatever setting is selected. This is awesome except for the fact that most settings will set up a very unpleasant harmonic thrumming sound. That's why a "fan speed controller" will have 3 distinct settings on it that match precisely with the 3 distinct settings you get by pulling the fan control chain on the fan itself.
You can do this, but you probably won't be happy with the results.
Instead, what you'll probably need to do is find a remote control dimmer that can be installed in the light housing and will control the dimming from the remote. You would want to find a system where either
  • the remote/receivers are programmable/pairable, or
  • there's one remote and 3 receivers, or
  • any remote will control any receiver
You would install the receivers in each fan, then use the one remote to control them all. You'd still have master control by flipping the switch on the wall to turn them all off/on (to the last brightness setting selected by the remote, assuming it has a "memory" function).
Fan fire
Fans are motors. They are not light bulbs.
"Dimmers" as you know them (i.e. triac dimmers intended for residential light dimming) do not reduce voltage, nor do they change frequency and phase the way a variable frequency drive does. They actually hack up the AC waveform to something really weird. This makes the dimmer cheap, and works fine with incandescents (LEDs have learned to adapt)... but Motors do not like this.
As such, it can cause the motor to overheat and catch fire.
As such, it is a code violation to put a dimmer on a fan.
Smart bulb
Your best bet here is to identify a "smart bulb" (think Philips Hue) which is able to pair with/be wirelessly controlled by a standalone "smart switch". Rewire the switch so it is bypassed: the fan/light is always-hot and is controlled by the pull-chains only. Then, install the "smart switch" in that box, so it taps hot and neutral. For the light pull-chain on the fan, coil it up and out of the way. It must not be used.
Do not abandon the room switch and use a phone or Siri or Alexa to control the fan. Code requires a room MUST have a light controlled by a physical switch in the usual location. That is so first responders can get the light on to do their job.
Another "just in case" if use an LED or CCFL with a dimmer would be worse than the harmonics with the fan ... there ARE LEDs designed to work with dimmers, but they cost more. Of course, if it's a filament it'll be fine regardless.
