Just installed the Sense / Square D Wiser Home energy monitor. The instructions state to leave the energy monitoring box somewhere inside the main panel. My main panel is a bit crowded with ground wires directly touching the sense energy monitoring unit. Any issues with this setup or anything else I should be concerned about?
In case anyone is wondering, the extra black and red wires that are clamped are from a generator inlet port. They are going to the first breaker on the right which has a generator interlock kit installed to prevent backfeeding to the utility company. I added the wires into the clamps so I can also measure when I'm running off of generator. This gives me the advantage of knowing precisely how much load I'm using and to keep it under the generator's limits.
