A question for the old timers(or any timers), have any of you demolished an older house that had a safety razor disposal slot built into a bathroom medicine cabinet? Was dealing with the dispised blades any more difficult than usual?
    Since your restricting answers to old timers I'll just comment that they fell to floor and I swept them up. No problem. – NoSparksPlease May 16 at 14:27
  • @NoSparksPlease A broom cuts through my overcomplicating, thank you. – bf2020 May 16 at 14:31
  • As a child I always imagined there would be millions of blades back there, but in the half dozen or so i've explored, there's usually none or a few dozen max. – dandavis May 16 at 21:39
  • There's a cute (ancient) SciFi short story where this problem is solved by installing a gadget in the back of every medicine cabinet that sends the used blades "elsewhen." – Carl Witthoft May 17 at 18:43
9
Many homes had the slot to drop used razors into. I use a magnet to pick up the old razors. Even rusty they can be sharp.
I used to wrap them in a newspaper so they would not cut through the trash bags. Today I would probably put them in some cardboard because we always have Amazon boxes to recycle.
If you find old Gillette razor blades, the coating on the blades makes a makeshift diode if you want to experiment and make a WW2 radio out of a coil of wire, an ear bud and razor blade - or that’s what my dad said. I was a sparky and we were told to rip out components, but that probably would only work on Hogan's Heroes.
    Thanks Ed, I had thought through the caution part but hadn't realized the need to consider safe disposal. – bf2020 May 16 at 14:36
    Or MacGyver ...... have found many Gillette Blue blades in between studs and wrap them in newspaper. +1 – JACK May 16 at 15:57
    +1 for the magnet. I place a piece of cardboard, (think cereal box) between the magnet and the blades. Slide the cardboard off the magnet and you have a no contact release. – mikes May 16 at 18:58
    I think you mean WW1; a cat's whisker crystal set. They had mass-produced superheterodyne receivers by WW2... – dandavis May 16 at 21:37
    @dandavis not in POW camps, that’s why the references to hogans hero’s – Ed Beal May 17 at 13:11
