I have just replaced lower watt LED ceiling lights with new, higher wattage LED ones. I have discovered that I'm using a Lutron TG600P toggle with sliding dimmer that is meant for incandescent bulbs. The LED's work fine and are dimmable.
What I want to do is to control the dimmer to a lower range - with the higher rated bulb the low end is a little brighter than I would like.
Is there a another settable control on the Lutron other than the sliding control to lower the low end brightness?
