I am installing floating floors in a 1970s condo where the door frames are metal. Side jambs are right against the concrete subfloor with no gaps.
I tried an oscillating tool with Bosch carbide-tipped blades and after a full minute, it looked like a fingernail scratch. My current tool is a cheap B&D - would it be worth borrowing a friend's tool to see if it makes a difference?
Another option was grabbing the right blade and getting down with an angle grinder. I have no experience using them and it honestly looks pretty frightening. However if there are no alternatives then I will just have to do my research and be careful.
The last option was renting an electric jamb saw tool and buying metal-specific blades. This path would be over $100 and some effort to find one as they are all rented out nearby.
Hoping anyone has better ideas for how I can undercut the metal! Maybe there's some secret multitool technique that I'm missing? Thanks all
