I am mounting a new large (150L) water heater inside a bathroom. What gap should there be between the top of the device and the ceiling? Some concerns:
  • heat retention instead of being transferred to the neighbours above
  • an unenclosed shower(-head) is located 1.3m away; so the lower the heater, the more water spray
  • space underneath.
My current bet is 0.2m from appliance to ceiling.
  • glass (enamel on steel) or copper tank?
    – Jasen
    May 14, 2021 at 23:54
  • Voting to close. Model is not listed and OP is apparently permanently absent.
    May 15, 2021 at 13:20
There should be minimum clearance specifications in the installation manual, so you should consult that. Anything else mentioned here is speculation.
You should shield the water heater from the shower spray.
    Enough clearance so that you can get the sacrificial anode out as well would be good.
    – gbronner
    May 12, 2021 at 1:24
  • it may not need shielding: some water heaters are installed outdoors and do not need addtional protection from the weather.
    – Jasen
    May 14, 2021 at 23:42
If the heater has a anode, you should make enough room above ir that it can be replaced.
Flexiblwe anodes are available. They tapically need about one third the height of the tank for fitment. The solud anhode that comes the the tank can be bent to remove it when it's time to replace it.
If there is unused space above the tank possinbly a hole can be cut in the ceiling to facilitate anode replacement.
