Probably a simple question, but as the title says, on the furnace side, is the Y/Y2 terminal the same as a Y terminal?
My furnace has Y1 and Y/Y2 terminals. The Honeywell thermosate says to jump the Y terminal to the G terminal on the furnace side as part of the procedure to setup the common wire for the thermostat.
So in my case, since I don’t have the specific Y terminal, would I use the Y/Y2 terminal? Thanks enter image description here
