What materials are required to cap off a 3/8” water feed at the valve?
I had a dishwasher. Its feed line connected to the water service under my kitchen sink right at the hot water shut off valve. I’ve removed that hose and would like to continue to use the kitchen sink. What do I need in order to cap off opening?
I have a compression fitting cap that fits on the threads, but this, by itself, does not make a water tight seal.
    How about a few picture so we can see what you see.
    – JACK
    May 9 at 20:45
    If you have a Y or T splitter on the hot water supply, you can remove that and hook the sink directly to the valve. May 9 at 23:43
I recently dealt with a similar problem -- I installed a water accessory and was faced with a 3/8" compression male outlet and nothing needing to be connected to it. A cap was easy to find at the plumbing supply but it didn't seal well. Wrapping the male thread with teflon tape plus pipe dope slowed the leak to a very slow drip, but the fact is the threads on a compression joint just aren't intended to form a seal.
In this case I got away with sealing it by placing a thick o-ring in the bottom of the cap. It sealed the cap to the male fitting nicely.
I was concerned the o-ring might wrinkle or buckle in some way during assembly, allowing the leak to continue. Had that happened I also considered carefully placing a brass or acetyl/delrin ferrule (without any tubing) into the male fitting, then place the o-ring around that, and finally install the cap. Maybe the ferrule would seal between the fitting and the cap, but if it didn't, it could provide some structure to help keep the o-ring in place.
  • I had the same problem, I was able to find a flat rubber washer in the big box store and it sealed fine. May 10 at 3:02
