I need to buy a 90 push in that has male NPT that matches this below hose end. I am not sure what to buy and if the 23-9/16" means 23" long hose and 9/16"ID for the compression fitting What 90 push in fitting that works with this should I buy?
Update: This is a follow up or a sequel of this thread Would a 1/2x3/8 Dishwasher Tube to Pipe Elbow, 90 take a 3/8 flex connect for a shower pannel? where I was told not to use the fitting I was asking about because it is for a dishwashere and it will reduce the volume. So now I am trying to find the right 90 that would be push in on one end and it will take the above compression hose
