Here is a video of the issue
I've just moved into a flat and after hand-washing some dishes this water cylinder (Dimplex SCx175l) began 'draining' very loudly -- I let it go for about 30 minutes before turning off the main water shut off valve.
I am assuming this is a problem with the T&P valve so I'm wondering if it is safe to turn the water back on or if I should call out a professional to solve the issue.
Thanks, Jack
  • You have only furnished the model name of an equipment/device that could be unfamiliar to most of the people here. Please indicate what type of equipment/device caused the problem, also the T&P valve.
    – r13
    May 8, 2021 at 16:24
  • @r13 I think you're imagining I know more than I do - everything in my post is 100% of the knowledge I have of the issue!
    – Jack Scott
    May 8, 2021 at 20:10
I have replaced the T & P valve in a gas water heater , no big deal just a good wrench. Mine was easier than yours because my outflow pipe went straight down to a floor drain ( concrete basement ). Also mine was just a slow drip leak . Because you need to turn your water off , it may be faster to call a plumber.
  • Thanks, I've asked elsewhere as well and the consensus is to call a plumber.
    – Jack Scott
    May 8, 2021 at 20:11
