Looking for any insight on my situation:
I have an A/C unit that is rated 15A, 1240W, 115V. Since all of the bedroom and living room outlets in my apartment are all on the same 15A breaker, I decided to run a heavy duty extension cord to plug this A/C unit into one of the few outlets that is on its own breaker. It's a GFI outlet in the kitchen and the breaker is rated at 20A. In order to reach the kitchen from the bedroom where the A/C unit is, I ran a 10-gauge, 30A, 50-foot extension cord.
After the A/C unit runs for about thirty seconds, the GFI on the outlet trips and the unit shuts off. I did some research before purchasing the extension cord and felt confident that it was a high enough gauge to not cause an electrical hazard; I also figured the 20A breaker would be sufficient since the A/C unit rated at 15A. However, I never considered the GFI on the outlet. Is the outlet possibly faulty or 'extra sensitive', thus the break after I turn the unit on?
Any help would be much appreciated!
