13
Neither myself nor a large group of people on a community chat can figure out what this tool is called or used for. It’s triangular with a thick solid 3 legged base, multiple flat wired blades (possibly blades), has a handle, and the rear legs are slightly higher than the front leg. We’ve had guesses (some of them hilarious) of everything from a cheese slicer, soap making tool, pastry cutter, blind cleaner, harvesting tool, to iron holder. It’s none of those. Someone must know!
    Welcome to DIY! Where did you find this tool? That info might help narrow it down. Also, take the tour
    – P2000
    May 4, 2021 at 14:48
  • The blades look too thick to use as slicer well. Does seem it might be adjustable for amount of blades.
    May 4, 2021 at 14:55
  • I was going to say "combination cheese slicer/concrete trowel", but since you ruled out cheese slicer, I'd go with some sort of concrete trowel. May 4, 2021 at 14:58
  • The standoff feet at the bottom rule out any sort of trowel. How do you know it isn't one of the things you listed? I think it might be for slicing fruit to go in pie. Like the fruit goes on the middle then you force it through the wedge
    – Matthew
    May 4, 2021 at 15:06
    The type of metal suggests it's for masonry or mortar. Perhaps it's a tool to spread mortar on a hard-to-access edge and the bottom is a stopper/hard edge. A thought crossed my mind that its' for heating up and scoring something meltable but the (apparent) wooden handle would overrule that. Very peculiar tool though. Where did you find it?
    – David
    May 4, 2021 at 15:10
13
The mystery has been solved, and it was discovered to actually be a vintage aluminum iron stand. I had found many antique iron stands that were similarly shaped, but none had the blade like structure around it. I assume their purpose is to prevent the iron from falling off while allowing heat to escape.
    Interesting. It's a very simple and effective radiator/heat dispersant
    – David
    May 4, 2021 at 17:42
  • Google Image Search can be your friend in cases like this May 4, 2021 at 17:51
  • @CarlWitthoft admittedly I tried, as well as ebay image search, with poor results, but yeah, Google Reverse Image search it's a good first resort.
    – David
    May 4, 2021 at 18:00
    The grille would be to prevent accidental burns or damage from inadvertent contact with the hot iron.
    May 4, 2021 at 18:18
  • @isherwood: Or possibly put glowing coal inside? No idea. May 5, 2021 at 8:55
