I'm adding some lighting to the attic and am running wires parallel to rafters. I need to go down the hip rafter and then down another rafter to get to where I need to go. Am I allowed to run the wire underneath the rafter to cross from the hip rafter to the other rafter or does it have to be drilled and through a hole to be up to code?
This is in the attic. Here is a picture of what it looks like. I'd be happy to add any more info if necessary. Thank you.
