I have a Samsung fridge freezer, with fridge on the top. The drain pipe in the fridge that lets the condensation out freezes near the bottom (near the freezer part) and blocks after just 2 days since I defrosted it. So then the drain overflows and a big pool of water at the bottom of the fridge. Has anyone else had this problem? Is there a way to fix it, or is it time for a new fridge?
EDIT: The model is a Samsung RL26DCAS. The drain pipe that is causing the issue is pretty much inaccessible. You can access the end of the pipe from a removable panel on the back of the freezer. but the part of the pipe that is frozen is slightly higher than this, and the only way to access it would be to take a saw to the metal panel on the back. I will try and add a picture later if I can.
