I successfully drilled through floors (see this), pulled Cat6 cables and terminated them with keystones. I tested everything and now am ready to finish the installation by installing wall plates
I want to put some kind of stopper on the cables, so that they don't slide down with their own weight. Initially I thought of making a single loose knot (~2") with the whole bunch, but not sure if this may be detrimental to signal quality.
What do you guys recommend?
(somewhat old photo):
(almost finished):
