I'd like two hang a pair of speakers on my wall. They are 6.8lb each. It is designed to hang on two screw heads spaced 1.5in apart. (Photo below)
I'm looking for recommendations on hanging.
- I have a bunch of 3M command strips. (Just the strips). I'm not sure if there's a plate or something I can get for it that would work with the speaker. This would be ideal as I don't have to put holes in my wall
- Can I just put two (drywall) screws directly in the drywall for each? They would not align to a stud.
- Otherwise, do I need to use a drywall anchor of some sort? I'm not sure about using two right next to each other. One is probably enough to hold the weight, but then the speaker wouldn't be straight.
