How does one frame a basement with steel studs where 1.5" of float is required? I reached out to the inspector and he said "...use a bottom slip track deep enough to accommodate 1 ½” of float."
How does one secure the steel studs to the deep leg track and allow it to float at the same time? Do they dangle there?
