My front loader electric dryer makes the room extremely humid and hot and it also forms condensation inside its display. The vents are not blocked and they are not leaking. It's a brand new dryer. What could the problem be? It's a maytag front load dryer, current model.
Manufacturer/model #? Traditional dryer or condensing heat pump dryer? Does it have any ductwork to the outside?– manassehkatz-Moving 2 CodidactCommented Apr 16, 2021 at 22:01
@manassehkatz-Moving2Codidact It's a Maytag front load dryer, current model on their website. I don't know what you mean by that but the previous dryer did not have this problem and we just swapped them.– SiphonophoraeCommented Apr 16, 2021 at 22:06
4The vent is not connected or is squashed and allowing wet air that should be going outside blast into your living space.– KrisCommented Apr 16, 2021 at 22:11
1The back of the dryer has a large port (about 6 inches diameter). Is there a hose attached to that port? Does the hose route to a passage in your house which goes outdoors?– Harper - Reinstate MonicaCommented Apr 16, 2021 at 22:31
1Are you absolutely sure you removed any and all shipping covers/plugs from the dryer before installing it?– K HCommented Apr 17, 2021 at 3:02
1 Answer
Most "traditional" electric dryers basically have a heating element, a fan, a motor and a control panel. The motor turns the drum, usually via a belt. The fan blows air past the heating element into the drum. The air then flows out, through the lint filter to the back (or possibly side) of the dryer through ductwork to the outside.
Anything can go wrong, but the most likely problem is that the air is going into the room instead of to the outside. That points to one of a few possibilities (more specifics would depend on looking at the manual for the specific model):
- Air blocked from exiting the dryer, resulting in it seeping out through any cracks/gaps and, therefore, going through the control panel (condensation) and into the room.
- Ductwork not connected properly at the back of the dryer. This would easily explain the air going into the room, but not the condensation in the control panel.
- Ductwork damaged, preventing air from exiting properly. This could result in air going into the room and/or air not exiting the dryer normally and instead seeping out through any cracks/gaps.
- Ductwork not connected to the outside. Presumably accidentally (because if it was on purpose, the old dryer would have had the same problem) and the air going into the room.
Check the installation manual to see if there are any dampers, multiple venting options, etc. that might explain the problem. Also check the ductwork to make sure that it is (a) connected to the dryer, (b) connected to the outside and (c) not crimped, squashed, torn, etc.
With typical ductwork, it should be easy to remove it from the dryer. That is important so that you can clean the ductwork periodically, because no lint filter is perfect, and dryer lint fires are a very real problem. One thing to try is to disconnect the ductwork from the dryer and then turn on the dryer for a few seconds. You should get a steady stream of air through the vent. If you don't, then the problem is inside the dryer. If you do, then the problem is in the ductwork.
The ductwork should be as long as it needs to be, but no longer. That is because every extra bend can collect lint or get crushed. The ideal setup is one elbow out of the dryer, one straight length of ductwork (best is solid metal, next best is flexible metal, worst (by far) is vinyl/plastic), then another elbow to get through the wall to the outside. Sometimes the ductwork has to be more complicated, especially if the dryer is not next to an outside wall, but every extra turn is equivalent to several feet of additional ductwork, and every fan (dryer, exhaust fan, etc.) has a limited effective distance.
If the ductwork is more than a couple of feet longer than it needs to be, cut it! With flexible ducts that is very easy. With solid metal it is a bit trickier (tin snips or replace with a pre-cut shorter length) but the end result will be a more efficient and safer dryer.
Thank you. I think it's option 1 or 3. It's a 20ft aluminum hose that is too long for the space and it forms a big S shape in order to fit behind the dryer. Could that be the cause? Otherwise the connections are perfectly good. I used a metal clamp + aluminum tape on both the dryer and end the wall duct and there is no hot air from behind the machine. The hot air seems to be everywhere else except behind the machine. Commented Apr 16, 2021 at 22:35
2Every bend in a hose can induce friction/trouble moving air. Possible new dryer has a less powerful fan than old one, and the S curves are acting to block air flow a bit.– crip659Commented Apr 16, 2021 at 22:46
1@crip659 I removed about 10ft of hose by cutting it in half and now the heat and humidity in the room has been reduced by about 80%. I'm guessing the rest is normal? Commented Apr 19, 2021 at 17:42
Wow! That's a huge difference. But that implies that either the twists resulted in something "open" that should not have been, or that the dryer just couldn't handle the load of the long ductwork and as a result was pushing air out through every leaky spot in the dryer. 20% still sounds like a lot, but that is a nice improvement. Commented Apr 19, 2021 at 17:54
