I can't get my whirlpool dishwasher to empty between cycles,,,I did change the control board and it didn't work,,it will empty with the cancel button, I do not have a disposal I cleaned out the bottom and cleaned the check valve,
    If you want any hope on this one, you should add whatever pictures and all of the troubleshooting information you have so far as well as the exact model of the dishwasher and link to the repair manual if you can find it. You might want to check exactly what if anything is wired between the control board and drain solenoid and drain pump. – K H Apr 16 at 1:57
    Did you contact Whirlpool to arrange service. – r13 Apr 16 at 2:13
  • @r13 based on the info given, that is about all we can offer in the way of advice, but let's give the OP a chance to edit more detail into her post before we make that the final offer. :) – FreeMan Apr 16 at 15:20
  • @FreeMan Sorry, I don't understand your message. I didn't vote to close this post in anticipation the OP will provide more information. – r13 Apr 16 at 16:26
    @FreeMan Got you. Thanks. – r13 Apr 16 at 16:41
