I live in a condo development and our patios are next to each other. Our neighbor recently removed some bushes that helped with the privacy. There exists two 8 foot sections of fence between the patios but we would like to add a third section on a 45 degree angle where the bushes were removed.
The companies that I have spoken with so far are telling me job is too small, or another post will need to be added and there will be a gap. Minimum labor of $600 plus material.
Question: Is there a way to cut into the existing post and run the new section of fence at 45 degree angle? (that is if i can find matching fence).
Hope this uploads and helps...where those small arbs are located my neighbor removed some larger shrubs that provided more privacy
