I'm installing some ELV garden lights and would be grateful for some advice on connecting up.
I'd like to control them from a spare light switch (the 2nd switch controls the exterior wall lights) just inside the back door as I have a cable already in place from an extension previously. The switch is currently wired brown (live) in/out of switch 1, the neutral is isolated in a block and the earth is connected to the backbox terminal. Considering I am trying to run low voltage lighting (6 x 3v) how should I wire switch 2, should I connect live/neutral and earth and similar to the outside socket? For info there is a plugged adaptor with the garden lights and outdoor socket will be IP66 rated.
Thanks in advance for your advice. Bren
