I am trying to remove some screws with some very annoying heads. The screws look like a regular Phillips head but have the center rounded out. This makes a normal Phillps head screwdriver slip as if the screw was already stripped.
I am looking for the correct bit to remove this, as I would like to reuse the screws later. That failing, has anyone had success removing screws with similar "pre-stripped" heads?
I have included an additional photo of another screw "as delivered." This close up shows the center of the head is square, with facets inside the square part of the head. For added context, every screw on the piece of furniture in question has the same head. If it is the result of stripping, the manufacturer was very thorough.
