I am carrying out some major driveway works soon, but would like advice on what to do with the electric meter.
The mains supply runs in the front of the property, goes into a garage there where the electric meter (Siemens S2AS) is located, and then carries on past the garage to supply electricity to the house.
So the garage is going to be knocked down, and a tarmac roadway put in it's place. However I don't know what to do with the meter? Once all the work is done I was thinking about having it in a small box or something near to the original location at the front of the property.
- Should I move it to a temp location? And can I do this myself, and get an electrical company to do a proper install later once I know where it's going?
- Should I just get on and get the electrical company to move it to it's final resting place? (not sure about this as the works are quite extensive and it could be in the way)
- Any other suggestions?
