We are dealing with a subpar contractor who has tried multiple times now to repair a small section of subway tile that they previously cracked. I suspect that their current strategy is going to lead to more of the same (poorly supported tile prone to cracking) and I would like to verify this suspicion before putting my foot down in what I request of them.
In the image you can see the current strategy. The drywall "bridge" which is in place between the studs has very little height around the J-Box (less than 1/2" on the bottom), meaning it is very non-rigid. Here is a video of my pushing on it (too large to host on this site). You can also see how poorly that drywall bridge lines up depth-wise with the backs of the other tiles which are in place. It's also worth noting that the tops of most of the tiles below the drywall bridge can be wiggled in place noticeably. I suspect that in the future these tiles will be prone to cracking, as well as any tiles which are installed over this shoddy bridge. As well as all of the grout lines involved, if the tiles themselves somehow manage to hold.
Assuming my thoughts above are correct, I presume the best course of action is to request more tiles be removed above/below the outlet to allow a better drywall bridge to be installed, one which has taller strips surrounding the outlet (compared to the flimsy 1/2" currently below it). But how tall is tall enough?
I'm inclined to just ask for a 16" square drywall bridge, which would give a solid 6" above and below the outlet hole. Is this reasonable?
