I need to prevent these windows from opening too wide.
I have a plan to drill into the bracket and insert a bolt to limit the range of motion, but before I start modifying I want to rule out a built in limiting/control mechanism I might be missing.
There is a clip and an unused hole in one area, but I don't see any way to use them to achieve what I need.
full crank mechanism
close up of rear section, possible adjusters, clip and unused hole
  • The clip might (or might not) be a limiter to affect whether the window opens to "egress" or further for cleaning (while having less clear area than at the egress opening size.) I have different windows with a somewhat similar clip. Speaking of which, if they are egress windows, you have to proceed carefully or may not be able to legally modify them this way.
    Apr 10, 2021 at 17:13
  • Based on their locations they are not suitable for egress, even in an emergency, and that's related to why I need to limit them, they are very dangerous as they currently are. Apr 10, 2021 at 17:47
  • Just because the windows open, does not mean you have to climb through them...
    – Solar Mike
    Apr 10, 2021 at 18:58
  • Any chance you can add a decorative chain to the frame opposite the hinges and window to stop the opening process?
    – JACK
    Apr 10, 2021 at 18:59
  • @SolarMike I'll tell my 2yr old Apr 10, 2021 at 21:38
