I have a number of long limestone bricks leftover after breaking down a large limestone planter. They're 2.5"x4", vary in length from 6" to 18", and some are mortared together. I'd like to cut them into 6" lengths and reuse them for a landscaping barrier. I already have a 10" jobsite table saw and a 7.25" worm drive circular saw.
Is my best bet to buy a segmented diamond blade for my circular saw and cut the bricks wet? Is it safe to use a 10" diamond blade on a table saw? (I haven't seen any mention of this online)
    Do not wet cut with a saw not designed for wet cuts. If you have to dry cut, wear a mask and use a vacuum to capture the dust stream.
    – K H
    Apr 11, 2021 at 6:35
    Cutting masonry on a regular circular saw will also destroy the saw before long. May 9, 2021 at 23:33
Something like this https://www.harborfreight.com/4-12-in-turbo-wet-dry-masonry-diamond-blade-68878.html and good angle grinder, at least 7.00 amp and dig about 1/4” all 4 side and little tap with small hammer would do the job. You have to rest brick (one being cut) on two bricks on the edge.
  • Any reason to prefer the angle grinder over a circular saw? Easier to control? Apr 9, 2021 at 22:06
  • Circular saw is okay. You can use it same way as circular saw, I mean scoring 1/4” all around and smacking with Mallet Apr 10, 2021 at 10:00
  • @user1445709 the roughness of the stone/brick will quickly tear up the sole plate of your circular saw, so you'll be replacing the saw much sooner than you would probably want to.
    May 10, 2021 at 13:13
