I bought a place that has a TV projector mounted to the ceiling. However, the mount is sort of a Y bracket that blocks the air filter from being removed and cleaned. I tried using a 3mm and a 4mm allen wrench on the screws in the Y but neither worked.
Assuming I get a 3.5 mm allen wrench and it fits, is this still the best way to do this?
It seems like I'm going to have to hold the projector the entire time or else I'm going to have the entire thing hanging by 1 screw.
The air filter looks like it needs about an inch of clearance. It comes straight up towards the ceiling, you can't pull it out horizontally at all.
