I just programmed my sprinkler settings for Spring. I have back and front zones. 1-5 in the back, 6-8 in the front.
I noticed that station 6 is not turning on by the timer. It reads Err.
Here's what I've tried:
- Station 6 turns on manually at the valve without the timer
- At the timer, I took the 6 wire and doubled up on the 1 station. Timer read Err.
- At the valves, I connected the 6 wire to the 7 wire/valve. I ran 7, and timer read Err.
Seems like any time station 6 is involved, the timer will read Err.
What kind of problem does this point to?
