-2
I need to have my house repainted and replace a large cedar deck. What order would you all suggest? Thanks.
  • Is the deck preventing access to any parts that need to be painted? – Andrew Morton Apr 5 at 11:39
    Do the painting, then it does not matter if you spill some. – Solar Mike Apr 5 at 11:51
  • Facetiously, yes. – MonkeyZeus Apr 5 at 11:59
    This comes down to the nuances of your situation. Since you've given us none, we can't say. Please revise to provide detail and photos. – isherwood Apr 5 at 12:42
    This is a very opinion-based question, so -1, but if it was me, I'd remove the deck, and install a new ledger (if applicable... ignore if this deck is freestanding), do all the flashing/ siding fixing, and then paint. – Aloysius Defenestrate Apr 5 at 13:39
Do the painting first that way if you spill something it doesn't matter (especially if you are doing it yourself) but keep a tin of paint just in case you need to touch up / paint some spots if the deck is in a slightly different place.
If you really want to play it safe, remove the old deck first. Then you can do the painting without any obstructions up against the walls. Afterwards, build your new deck.
  • OTOH, use the deck to get extra reach to the high spots that need to be painted. Hence, opinion based question. ;) – FreeMan Apr 5 at 12:32
  • @FreeMan I actually thought about that but figured if the deck was being replaced, it must be in bad shape and wouldn't want to be working on it. – JACK Apr 5 at 12:37
    There's a large span between "looks bad enough that it should be replaced because it's ugly and going to become a problem" and "on the brink of collapse and unsafe to stand on". And that's ignoring pure size/aesthetic reasons someone might want to replace a perfectly good deck. – Dan Is Fiddling By Firelight Apr 5 at 13:19
