I am trying to install a sense device in my electric panel to track my electricity usage. More information here. However, my panel is full, and I am trying to make it work without getting a new panel altogether.
I have sketched out two options, before installing the sense, a section of my electric panel looks like:
First solution is to "piggyback" on an existing double breaker:
Second solution is to install a new quad breaker to group Bedroom1,2 and garage door there and have the sense use the old breaker that was used by the garage door:
My understanding is that solution 1 potentially does not meet the code, and solution 2 is fine but involves buying a new breaker. A better but significantly costlier solution would be to install a new electric panel. Is my analysis correct?
N Amps
instead.
