I need to fasten a 3/4 inch PVC trim board to a poured concrete basement wall. Since this will be on the exterior of the house I want to avoid rusting of the fastener. The previous pressure treated board fell off when the concrete nails rusted and broke off. I was considering using Tapcon screws and counter sinking the heads and filling with a paintable epoxy. I know the Tapcons will rust at some point. Does anyone know of a stainless steel concrete fastener?
1Most coated fasteners should last a lot than common non coated fasteners. Tapcons are coated, but could get galvanize or other coatings. Most will last much longer than non coated fastenings.– crip659Mar 28, 2021 at 22:12
2You should just drill and insert anchors, into which you would drive stainless-steel screws.– Jimmy Fix-itMar 28, 2021 at 23:01
Tapcons and similar are available in stainless:
https://www.tapcon.com/products/concrete-screw-anchors/410-stainless-steel-tapcon
You have various options. The thickness of the fastener matters. Really a hot dipped galvanized fastener of sufficient thickness should last decades. Are you close to a marine environment? - that will speed oxidation of fasteners.
If you want the fastener to never rust out you could go with stainless steel and epoxy. Something like HY-150 or there is a simpson strong tie version. A lot of structural components are drilled and epoxied into concrete so certainly this will work to hold up a simple panel.
I have some pvc panels that I plan to install on concrete - I'll probably just use the strongest PL - PL Premium. Seems like PVC is listed as compatible.
PL is construction adhesive? It's not a marine environment, just exposed to snow and rain. I tried a construction adhesive but it did not hold well on pressure treated and concrete. What is HY-50?– GenkiMar 29, 2021 at 0:28
1Yeah PL is construction adhesive - the materials have to be dirt / dust free. Is the PVC panel touching the ground or free hanging? HY-150 is a two part epoxy made by Hilti. loctiteproducts.com/en/products/build/construction-adhesives/… Mar 29, 2021 at 1:08
1@Genki PL Premium is polyurethane so it may act different than solvent-based construction adhesives. PL needs to cure under pressure or it doesn't stick well.– piojoMar 29, 2021 at 13:56
Thanks for the info. The panel will be under a walk out basement door aluminum threshhold. The bottom of it is only a couple of inches off an asphalt surface but there is plenty of splash from roof runoff. My plan now is to drill some 3/8" holes, fill them with epoxy and fasten the board with SS trim screws into this epoxy, when cured. Back it all up with PL.– GenkiMar 29, 2021 at 22:20
