We have bedrooms above the garage and I am trying to reduce the noise from the garage doors. I have installed a vibration isolation kit like this on the opener/motor, which already made a huge improvement. But I can still hear some noise from the door running in the track.
I was thinking of installing another set of these rubber dampers in between the track and the ceiling bracket, but I noticed that the screws holding the bracket on are orange, which, according to Google means that they are under tension. But I can't figure out how there could be tension on this part, since the spring is attached somewhere else completely, and the cable is attached to the bottom of the door.
Is there really tension here? If so, is there a way to install these in this spot without having to unwind the springs?
