I just got new cabinets and am going to be installing LED light strips on the under-sides of the shelves for effect.
My experience with these strips in the past is that the adhesive backing is not very strong and wears out after a few months despite it having the 3M label. I would like these installed well the first time, so that I do not have to mess with the cabinet lighting again for decades if possible.
I've considered adding a dab of super glue to points along the strip, but then I worry if I have to replace these in 10 years, I won't be able to remove the old strips. On the other hand, I've considered a bead of silicone because it's clear and can easily be removed with a scraper.
What may be other options for fix the LED strips in place, other than super-glue? I need them to be fixed well enough in place to last years, but also for me to be able to remove them if necessary without ruining the shelves.
  • Welcome to Home Improvement. If you'll take the tour, you'll note that this is a Question & Answer board, not a general discussion forum. Unfortunately, you question, while valid, falls more into a broad general discussion/shopping recommendation category and neither of those are on topic here. That said, you may want to consider using screws - their "adhesive" doesn't wear out, and they make removal/reinstallation very easy.
    Commented Mar 24, 2021 at 16:26
  • This is not a very good suggestion, considering screws would penetrate the circuitry internal to the light strip and short it out. Commented Mar 24, 2021 at 16:34
Strengthen the supplied sticky backing with something better at all stress points (beginning, end, change of direction, near any switches or other places the strip will be handled).
Options:
  • double sided foam tape
  • A bracket made of a strip of wood with wood glue and/or screws
  • A metal bracket ... just a thin strip of metal that runs across the light strip and is screwed into the underside of the cabinet tightly.
  • Thank you for the suggestions. I might consider the double sided foam tape. The bracketing suggestions, while technically sound, would cheapen the look of the cabinet. Great suggestion though if I were installing these in my shop. Commented Mar 24, 2021 at 16:45
  • The tape is probably easiest but if you are looking for good looking, rather than the crude brackets I pictured, look at woodworking or furniture / hobby supply for similar things that are designed to be attractive. There are shiny brass ones, ornate bronze ones, etc etc.
    – jay613
    Commented Mar 24, 2021 at 17:32
