We're adding a bar sink into the basement of our house while we are finishing it. The location is at a place where we can attach to the drain just fine. The issue I am running into is that I am not able to or clearly almost impossible to connect to an existing vent on another end of the basement due to HVAC.
However, I do have a much cleaner direct path to an outside wall. I am in Minnesota and the currently adopted code is 2015 version. http://epubs.iapmo.org/2015/Minnesota/index.html
Now the location that the vent would exit the sidewall meets all these criteria. I want to know if I am going to have any issues and I don't see why I could not do it this way.
  • Not directly below a door, openable window, or other air intake opening (of this or any other building).
  • Not within 10 feet horizontally of the above-mentioned openings, unless it's 3 feet above them.
  • Not less than 10 feet from the property line.
  • Not less than 10 feet above the ground.
  • Not under the soffit, if soffit vents are used (Covered by point 1 in my opinion).
  • Must be protected from birds and/or rodents blocking it.
  • As it is a code related inquiry, you should copy and paste the relevant code provisions, or indicate the section, in the question. Otherwise, unless a person happen to be familiar with the MN residential code, no one can respond with certainty without going through the code. – r13 Mar 23 at 19:35
  • Have you investigated air admissions valves (AAV?) – Ed Beal Mar 23 at 19:40
