Hi I need to get this vent/pipe replaced but I don’t know what it is called. Can anyone identify it for me. It’s in my basement near the furnace.
  • What is the other end connected to? Is it actually cemented into the wall as it appears, or is there room around it to easily remove & replace it? Could you maybe provide a pic from the side? How big is it? – FreeMan Mar 22 at 16:15
Lacking context, it's either a cleanout (normally at the bottom of a flue) or a disused thimble (place where a pipe used to connect to the flue) with a cover/plug in it (the half-rusted bit with the handle) - "cleanout cover" and "end cap" and "flue plug" are all possible names when searching. Add the diameter of the pipe/hole to narrow results towards ones that might actually fit.
