I am seriously considering buying a very old apartment in an old Swiss farmhouse.
I want to know if the floorboards can be saved. They have gaps between them of about .8 cm to 2cm. Some of the wood looks like it has been infested with some sort of bugs. I have attached a picture of the shells of the bugs I have found.
My initial idea is to find the same type of wood and cut it to size to fill in the gaps and then sand it all down and stain it. They are also visible nails in the floorboards.
So my main question is can the floorboards be saved, do I need to get rid of them in order to get rid of the bugs?
