I'm framing the roof of an 8x10 shed with a loft overhang:
The plan I am following has no ridge beam nor ridge board and instructs me to "screw or nail the rafters together at the peak" which seems a bit vague/insufficient to me. Here is a photo from the plan:
The rafters will be fastened to the loft joists, but I'm wondering how exactly I should be fastening them together at the peak. I've been considering plywood gussets or metal truss plates--I want to maximise headroom in the loft, so they would need to be fairly small. Since most of the rafters are tied together at ceiling height (due to the loft joists), I initially thought I would just need to connect them in a non-structural way that emulates what a ridge board would be doing (alignment, basically). However, I'm a little anxious because of the steep pitch (16-12), especially after finding out that past 12-12, a structural ridge beam should be used instead of a ridge board. I'd rather not add a ridge beam in (nor a ridge board, for that matter).
Where I'm building, there are about 2 weeks of snow per year and a lot of rain. Uplift winds are something of a concern as the structure is atop a hill.
How can I safely fasten my rafters together at the peak without compromising headroom?
