Moved into a new construction, I was recently trying to install a ceiling fan. There are 4 wires coming out of the ceiling outlet box,
- Black wire
- White wire
- Red wire
- Bare copper wire
Wired the ceiling fan as instructed, black from ceiling to black from receiver, however this doesn't work.
My assumption was that black wire from ceiling is hot. When I use a non contact voltage tester, there is no voltage detected at the black wire, there is voltage detected only at the red wire. Is this normal?
