A friend of mine took down a ceiling fan to put up a light fixture. He was unable to get the light to work so he asked me to take a look. There is a 12/2 cable and a 12/3 cable coming into the junction box in the ceiling. I tested all of the wires, and there does not seem to be a neutral wire present. I took a pigtail light and touched it to all of the possible wire combinations and cannot get it to light up. If I touch one of the pigtail wires to a ground wire and then touch the other wires, all of them are carrying enough power to make the light work. I tested all of these wires with my multimeter and the black and the white in the 12/2 cable carry 120 volts, and in the 12/3 cable a white and a black one carry 120 volts and the red carries approximately 68 volts.
What could be going on here? I'm an experienced electrician and this doesn't make any sense to me.
Additional information: There are 3 different ceiling lights total on this switch circuit. There are 2 3-way switches and 1-4 way switches. I tested the switches and they all seem to function just fine. My friend said he did not mess with the other 2 lights or any of the 3 switches. Flipping the switches doesn't change the voltage at the ceiling box. He said the ceiling fan worked fine before he took it down.
