I would like to install a wired security camera box in a closet and run the cables up into the attic to the individual cameras. How should the cables penetrate the drywall ceiling? I would like the install to look polished, minimise the access of creepy crawlies from the attic into the main house and allow for the addition of more cables in the future. The best I've been able to dream up is a short length of PVC pipe inserted in a corner of the ceiling, that gets stuffed with fiberglass insulation after running the cables, but that seems inelegant. Any better ideas?
Replace "Pipe" with "Conduit" and "Fiberglass insulation" with "duct seal" (note: the electrical conduit kind, not the air duct kind) and put a couple of bell-end fittings on the ends to make it nice (Or just ream the sharp corners off the inside of the cut ends really well to be inexpensive) and you have a normal workmanlike method of achieving your goal.
It will look more polished if the conduit extends all the way into the security camera box, rather than just poking through the ceiling above the box.
  • Thanks, @Ecnerwal. Apparently, there's a whole world out there that I never knew existed.
    – Paul Price
    Mar 16 '21 at 5:14
  • Congratulations on 100,000
    – JACK
    Mar 17 '21 at 13:33
  • Thanks Jack. I've been trying to take a break, but my fingers keep hauling me back here as if on autopilot...
    Mar 19 '21 at 0:43
