I have a standup shower that has a hose attachment, sort of like this one that screws on to the shower arm coming out of the wall. Unfortunately due to our hard water I am unable to unscrew the attachment any longer as sediment has built up all around it.
The faucet is turned totally off (100%) but water is still dripping out of the shower head (its been weeks). This tells me the leak isn't with the hose attachment, but in the shower arm, or rather, the valve inside the wall.
I would like to cut the hose attachment off and cap it. Later this spring I'm going to tear the whole shower out and replace it, but for now I just want to get the leak to stop. I imagine that once I start cutting the shower arm, water will start trickling out, and there's no way to tell how much there will be.
Should I tear out a panel of wall in between the faucet and the shower arm and see if I can replace the valve? Or is it probably OK to cut the arm in between the wall and the shower head, deal with a little bit of water trickling out and find a way to "wet cap" it somehow (place a cap and glue it on/seal it/etc. while water is still coming out)?
