I have a question regarding the cellar floor of my 1950s house in germany. It has a concrete floor. In one room there are a lot of cracks in it. They are meters long, but only a few mm wide. When there are very heavy rainfalls and / or heavy snow melt, these cracks are wet. (Happens approximately once a year) The water presses up from down the foundation.
This never was a big issue, because after some days it is always dry again. However now this particular room should be renovated as a hobby-room. Among other things I want to lay out a PVC coating. Now if I would lay the PVC coating above these cracks, it would most likely start to mould under it, when the moisture comes.
So my question is... Can I somehow repair / seal these cracks, so the moisture stays away?
enter image description here enter image description here enter image description here
You are correct that a surface cover will not resolve the issue and it's likely to disrupt flooring if done that way.
There are several commercial products for concrete foundation repairs, they are typically epoxy or polyurethane "injections" (this term may help you find some in your area but I do not know the German translation for the phrase "concrete injection"). The visible surface of the crack is temporarily sealed and then the epoxy applied with pressure so it pushes deep into the crack to seal it from the inside (or other side, if possible). In my experience these typically don't require drilling through the concrete so you can apply to the earth side, but variations may exist.
Read and follow the directions of whatever product you choose. Cracks are more commonly addressed in foundation walls so make sure your product is also rated for application to floor cracks.
