My basement has overhead LED can lights that were installed by an electrician 7-8 years ago, sometime after the house was built. It looks like they powered them by running conduit to tap into an existing light switch at the base of the stairs. Complicating matters, that light switch they tapped is a 3-way: there is a switch and a light in the basement, and a switch and another light on the stairs.
I was thinking I'd like to put in a smart switch for the overhead lights (a dimmer, to replace the current "dumb" dimmer). I have done several others throughout the house, but only one 3-way and none were "aftermarket" connections like these lights. When I opened the switch plate to see what the setup was and take some pictures, I immediately ran into some problems.
I see three romex cables entering the box- one is from the LED lights, one I identified as the 3-way with the traveler red wire, and one I assume is source power (but cannot be sure of the internal layout of the 3-way).
First, I found the white wire coming from the LED lights pigtailed and electrical taped to a ground copper wire. After having a few words exclaiming how long I've lived here and never seen that, I disconnected it. I have refused to reconnect it, but possibly as a consequence, the overhead lights have not worked right in a rewiring attempt. I'm hoping that I'm missing something obvious, but in my attempts in using what I thought were the correct hot, ground, and neutral wires, the LED lights become tied to the 3 way switch.
Possibly related to this confusion is the romex cables I thought were the source power. If I unplug every wire in the box, only one tests hot: the WHITE (no black tape) wire coming in through that 3rd cable (not the one to the LEDs, not the one with the 3-way runner).
Please see my attempt at a sketch below that represents what is currently in my wall.
Here are my questions:
- is that actually a line to the breaker with an always-hot connection, given the other issues? Or is it likely to do with a light on the 3-way? Is there another way I can test this, given that so far it always comes up 120v?
- if it is source, would the black wire then be neutral and white hot (chalking it up to the installer's error) or is it marked correctly and something else is afoot? With everything disconnected, the only voltage is on that white wire.
- Is there any way to identify where the always-hot wire enters the circuit if it is not in this switch box? If so, is there any way to bring it to the box at issue?
- If the current setup does allow me to reinstall a switch, how should it be connected given the flipped wires and the pigtailed hot? Should I just add a jumper into that hot pigtail for a hot line to the LED switch? Where do the hot, neutral, and load connections go? I would normally think: -switch hot screw to that pigtail with the hot wire -switch load screw to black LED wire -white LED wire to neutral (possibly that unknown black wire?) -switch neutral screw to neutral wire
...but given the three-way and the possibly reversed colors I'm at a loss for the moment.
**Also in image I omitted the wires coming in from the LEDs as they're capped for now
Any help is greatly appreciated!
Edits: Here are pictures/diagram of original wiring as close as I could get them. I admit I immediately disconnected the white/ground pigtail before taking any pictures, so I cannot be 100% which white wire and ground wire it was. I suspect the white coming off the LED lights because otherwise it wouldn't be connected to anything, and the ground coming from the unknown romex (A in the sketch), because otherwise it also would not be attached to anything.
Also worth pointing out, the other end of the 3 way is a single gang box with just the other end of the wires from the box of interest. There are no other cables going into the other 3-way box. I’m no electrician but at I assume this tells me that the power source is likely to be connected to one of the lights, given that the box I’ve been exploring appears to be a switch loop per feedback so far.
Pics couldn't get a great angle thanks to shorter wires on the left 3-way switch. The original Lutron dimmer is on the right, and has 3 built-in wires: red, black, and a taped off unused red/white since it's not part of the 3-way. The electrician connected a green jumper from the dimmer switch to ground instead of just using the copper ground. I have more pictures but it starts to get cluttered.
I guess the consensus is that this is a switch loop and the electrician cut corners. How should I have this fixed? Can the original 3-way be left as is, and I just need to run a line tapped to actual power from whichever of the lights has the source power (there's no outlet on this wall, it's about 4 feet long and just walls off between the stairs as they rise and double back from a landing, the other side is a closet). Would there be a way to identify source power to tap if I remove the light fixtures? Definitely will hire a professional for that part, just want to do my homework first. Thanks again everyone.
