In some of my rooms the baseboard touches the tile (you can see a slight gap at times). Even the door casing is on top of tile.
In this bathroom (after removing the tile) it looks like they put the sub-floor down, then 1/4" underlayment then the baseboard and then the tile.
My photo is of sub-floor & under lament with removed tile and exposed baseboard.
Which method is "best practice"?
my bathroom
EDIT 1: Here is a wider view enter image description here
  • What exactly is the problem you are trying to solve. Do you want to know if you should remove the base board, then tile and then re-install the base board? if so, then Yes.
    – Alaska Man
    Mar 7, 2021 at 23:28
    Your photo is not showing any exposed baseboard. In fact the baseboard has been removed entirely as evidenced by the the ridges on the wall a few inches up from the floor. What you see on the wall is the drywall material that was behind the baseboard and under the paint on the wall.
    – Michael Karas
    Mar 8, 2021 at 4:05
  • @MichaelKaras You may be correct but the scale of things in the photo is deceptive. I think the ridge is were the tile met the base board. Based on the OP's description.
    – Alaska Man
    Mar 8, 2021 at 4:15
    @AlaskaMan - The photo is not deceptive at all. I think your understanding of the photo is questionable. In fact I suspect that what is going on here is that the OP is calling the wall board the "base board" which of course is incorrect.
    – Michael Karas
    Mar 8, 2021 at 4:18
  • Much about my understanding about many things is questionable. The rows of thinset are extremely large if you are correct. I would agree with you if not for the OP's description. Perhaps the OP is not sure what Base board is. I am assuming trim not drywall.
    – Alaska Man
    Mar 8, 2021 at 4:21
The answer you are looking for is... it is up to you.
Baseboards are there...
  1. To make sure a wall does not get kicked or damaged at the bottom.
  2. To hide flooring gaps.
  3. For decoration
  4. For a good excuse to buy a mitre saw.
Depending on the type of flooring you install you will want to adjust your base boards or even install different types.
Michael says you may need a base shoe - warning I am an anti-shoeite. Why why? Why the extra piece at the bottom that gets broken or comes loose. I have never been in a super upscale house and saw a shoe stuck to the bottom of trim.
So some guidelines:
  1. Carpet = 1/2"... if you are getting some super dense stuff maybe a little more. If you are getting stuff that might not even be considered carpet (I call it astro-carpet) then maybe less. It should be tucked into baseboards. Meaning if baseboards install after you should slightly smash down carpet at edges.
  2. Wood = You should be installing after and lay it on the wood. So not all floors are exactly level-perpendicular should you have have gaps underneath some sections. This is OK and aesthetically each wall should be laid out to look good and join at corners well. Note that if you are leaving 1/4-3/8" you have the option of getting trim that is thicker to cover this. You can also find trim that is thicker at the bottom, which is all you need.
  3. Tile = You also should install it after as you should not be grouting between tile and baseboards. If you were a pro and had installed a certain tile before I guess you could leave the baseboards and slide tiles under... that is not normal though. For gap on tile I like 1/8" all the way around. Two reasons... It shows better. If one tile is slightly slightly higher you won't notice as much if baseboard was sitting on it. Also you won't notice grout issues or divots that are perpendicular to baseboards as much.
  4. Vinyl/planking/engineered - treat these like wood.
I have done shoe moulding on two out of my last maybe 50 flooring remodels. One was because my guys had uneven and big expansion gaps (install mistake). The other the lady explicitly wanted it even when I tried to talk her out of it.
How big the gap is... well it really comes down to what looks nice? I would for instance welcome a larger than I want gap to forgo shoe moulding (I know those two are not really related).
Best practice is that something at the lower edge of the wall should come down on top of the finished floor surface. If you install baseboard alone then that should be installed last over the finished floor. On the other hand if the plan is to install a base board plus base shoe then you could choose to install the baseboard first and then run the finished flooring material up to the baseboard and cover the final installation with the base shoe.
Since many modern choices of flooring used these days are typically installed with a 1/4" to 3/8" gap of the finished flooring from the walls this can be difficult to cover adequately with just a base shoe as the material is fairly thin. In these cases it would be strongly recommended to install both the baseboard (and baseshoe if desired) after the finished floor surface is installed.
