My house has older wiring and a lot of stuff is rigged in a weird way. When I installed the Kasa switch, I was careful to only connect black to black and white/neutral to neutral and ground to ground (green). But i will confess to playing “wiring roulette” when I noticed that the lights came on, but would not turn off.
The old switch that was in there only has a black connection and works fine. However, it appears to use the live load connection from two different conduits in the wall.
I have no idea how to connect the Kasa so that it will use these wires and “switch”. It connects to the WiFi just fine, and as I said the lights are on but just won’t turn off .
Any help appreciated
old wiring
kasa switch
I tried the solution provided and it didn’t turn on the light at all. The old switch seems so simple, using only the black, but I don’t know what I’m doing wrong. The Kasa SmartSwitch was getting power and connected to my wifi, just didn’t control the light, on or off. I put back the old switch the way it was, and it works just fine
live wires with kasa
no current connected together
old switch
old switch black wire going back into wall
    Did you go black to group of black, black to black, green to ground and white to the group of whites? I.E. Explain how you had it wired when it was not functioning.
    – Alaska Man
    Mar 6, 2021 at 20:10
  • Do you have a multi meter? Are all the black wires disconnected from every thing?
    – JACK
    Mar 6, 2021 at 20:33
The whites and greens are pretty straightforward.
However I believe this switch has two black wires. One of them should be identified as "Line" or "Supply".
Also, 2 black wires went to the old switch.
I want you to connect the "Line" black wire to one of the 2 black wires that went to the switch - preferably the one that is nutted to other black wires.
Cap off the other 2 black wires (1 from switch 1 from wall).
Now, see if the smart switch will power up and identify itself on the Internet. If it does, go to the next step. If it doesn't, you got the wrong black wire.
Once the switch powers up, there you are with 2 black wires capped off and unconnected. Connect them to each other and the light should now work.
  • I was hoping you would answer, because I wanted to send you a message of thanks for your answers to other questions. Your comment about “roulette” on another electrical question both had me laughing and taught me something at the same time. I will try your solution and let you know!
    – dq72
    Mar 6, 2021 at 23:42
  • Thanks for providing this answer. It didn’t quite work. I have posted some additional images if that’s helpful at all and I thank you for helping in the first place
    – dq72
    Mar 7, 2021 at 19:03
  • @dq72 Weird. From what I can tell from those potato photos and a bit of web searching, Kasa doesn't seem to have a distinct Line vs Load hot wire - I guess they put in the extra circuitry to let it power its own electronics from either one, so it wouldn't matter how it was installed. I have faith that you are wiring it correctly, since you are easily able to rollback to a plain switch. All that's left seems to be "faulty switch". Mar 7, 2021 at 19:23
  • Ok thanks. I guess I can try to install the kasa at another outlet switch in the house (maybe one that is a bit simpler) and see if it works. If it doesn’t, that maybe would isolate it to a bad switch
    – dq72
    Mar 7, 2021 at 21:44
So, this is an extremely late answer, but your problem (as far as I can tell from your pictures) is that you wired both of the black wires from the switch into the same wire nut, apparently to the supply hot line (assuming that red on your tester means that it detects a live line.)
In the switch box, you should have (at least) the following lines:
From the supply:
  • supply hot (usually black)
  • supply neutral (usually white)
  • supply ground (green)
From the light fixture:
  • switched hot (usually black)
  • fixture's neutral (usually white)
The green (or bare) wires are just for grounding safety. They aren't part of the circuit that operates the light.
The two black wires that went into your original switch are the supply hot and the switched hot. The complete circuit that powers the light should allow current to flow from supply hot through the switch to switched hot, then through the light fixture, to the fixture's neutral, then to supply neutral. Presumably, the fixture's neutral is combined with the supply neutral in your bundle of white wires that are nutted together. The circuit is then controlled switching whether the supply hot and switched hot are connected at the switch.
Your new circuit through the smart switch should be nearly identical to the original configuration, except with an extra neutral (white) wire running from the switch to your bundle of neutral wires. In particular, one of the black lines from the switch should be attached via wire nut to the one of the black lines that went into your old switch and the other should be attached to the other black line that went into your old switch. But these should not be attached to each other!
This will form a circuit to power the light in the exact same way as your previous regular switch, with current flowing from supply hot to switched hot through the two black wires going into the switch.
The neutral (white) wire coming out of the switch is used only to power the electronics in the switch itself and is irrelevant to powering the light. The white wire from the switch exists only so that the switch has a complete circuit to power it even when the light is switched off.
Given your picture showing how the Kasa switched was wired in, your explanation of the behavior makes perfect sense: the switch was receiving power because its black wires were attached to the supply hot and its white wire to the supply neutral. However, the switch wasn't attached to the light fixture at all, so that's why it powered up and connected to the Wi-Fi, but didn't actually affect whether or not the light was lit.
