Can anyone tell me what this nut is called and how to remove it in a way I can return the mechanism to normal working order? Also, what kind of special tools will I need?
The first photo is of the outside end-cap of a set of vertical blinds. The gear on the other side, not shown in the first picture, connects into a long shaft used to rotate the row of blinds to vary the amount of light coming through a glass door.
I'm actually trying to replace a broken axle that held some pulleys for the draw strings purposed to slide all the blinds in one direction or another. However, the pulley axle was located in this end-cap assembly. In order to get to their area, I need to remove this end, it looks like, and the only thing barring removal seems to be this weird looking nut.
Second photo is a view from the other side which shows how the gear couples to the shaft. Maybe there is a different way to uncouple and remove the end cap?
push nut
, it's not truly a "nut" since it has no internal threads, and the piece it attaches to has no external threads. It's more along the lines of aretaining clip
and sometimes called aShaft Retainer
. As @george-anderson mentions, they are commonly referred to aspush-on fasteners
. One brand of the item isStarlock® push-on fasteners
. A similar item that is designed for use on a threaded shaft is called aPalNut®
. – Kevin Fegan Mar 7 at 4:07
