I have a metal spiral staircase that has an existing coat of paint, but I want to re-paint it white. Do I need to remove all of the existing paint before I re-paint it?
I’m not sure exactly what kind of metal or what kind of paint the original coat is, but the paint is in great shape and there is no rusting or anything. The treads used to be covered in carpet and so there’s glue residue on them that will need to be removed, but I’d rather not have to go through the tedious process of sanding down each individual railing (further than a rough sand to allow a bond to the original paint).
A related question is whether it would be ill-advised to use the standard semi-gloss paint I’ve been using for the doors and trim around the house, but I’m guessing it’s best to use a more specialized paint. I plan to get tread covers for the steps so the paint won’t need to hold up to traffic, but I certainly want to do the best I can to make sure it won’t peel or chip any time soon.
Thanks!
