It's been many years since I built a deck, and never a two story one. Existing deck getting replaced, it's a two story, with the pitch of the house roof (1) extending a few inches past the face of the deck. Note I said a few inches.... What is the right way to mount a support column to a deck and to a header? won't work for me as it would put the deck past the drip line!
County will accept a rough-drawn sketch (sketchup) for a permit, when I called about this question, was informed they issue permits, if I need design, call an engineer! Any way, my question is about the rim joist to post connection. My knee-jerk reaction is the notch the post and use a single 2X6 (3). Or do I need a double header here (4), if so, doesn't notching a 6 by 6 post...3 inches...too much?
My second question is, what about when two rim-joists meet? I assume I meet them in the middle of the notch (5)?
Can't use existing deck as example, there's a reason why it needs replaced.
