-1
Last summer we bought a shed and panelled inside with tongue and groove panelling. We put up damp proof and insulation first and then the panels on top. We used panel pins on every third board. Over the winter it seems the wood has expanded causing it to push out in places. How can we fix this and can we prevent it happening again?
    Any pics to show the extent?
    Mar 1, 2021 at 14:19
  • Is the space temperature controlled?
    – jwh20
    Mar 1, 2021 at 14:30
  • Sounds like moisture trapped in the insulation.
    Mar 1, 2021 at 14:35
    That's very odd. Wood usually contracts in winter. Is "winter" where you are actually warm, but humid?
    Mar 1, 2021 at 14:53
  • To add pics, click the edit link, then simply drag & drop the pics into your post. The site will upload & host them for you. If you can't do that, post them to imgur.com or similar and paste the links in the comments, someone will embed them for you.
    Mar 31, 2021 at 18:07
Your shed may have shifted. I have a larger shed that had this wood veneer nailed to the walls, and it's shifted somewhat, which warps the paneling.
I would make sure your footings and walls are still level. If they aren't, you can use a car jack (use a car stand for a safety backstop) to raise the shed and add supports to raise it back to level.
  • Thank you for your replies! I’m in Northern Ireland, so our winters are wet and around -3C to 12C. Could have made it damp inside shed. We stapled black damp proof to the shed walls and then packed the space with insulation that came in a thick roll before panelling. Is that the correct order? I can’t seem to add a photo. It is worse around the door and window. We haven’t got any hearing in the shed. If we can fix it we will air it out more often and use a space heater occasionally on it throughout winter. Would this help? Do you think the wood will shrink again as the weather warms? Mar 2, 2021 at 15:27
