I am running a #6 wire from my sub-panel to an electric car charger. The car charger only has 3 inputs, for the hot, neutral, and ground. It's the Tesla Gen 3 charger with the manual and diagram found here.
Home Depot doesn't carry a 60 amp, single pole Square D breaker. I picked up this 60 amp double breaker here.
Can I run both hot wires from the 2-pole breaker into a single slot on the Tesla Wall Charger?
